Draw Line
Interactive - Cursor
  • Click the left mouse button to indicate the start point of your line.
  • Move the mouse pointer and click again to set the next point in your line.
  • Repeat this process to add as many line segments as you require.
  • Right-click or press Esc to finish your polyline and exit the form.
  • Alternatively press the Space bar to complete this polyline but keep the form open and begin drawing another polyline.
  • Press the Tab key to automatically close the vector.
Creating Tangent Lines
From A Point To An Arc
From An Arc To A Point
From An Arc To Another Arc
Quick Keys
  • Left-click and drag out your shape in the 2D View.
  • With the left mouse button still pressed, enter a quick key sequence detailed below.
  • Release the left mouse button.
Examples
  • 3 . 5 Enter - Adds the next point at a distance of 3.5 along the line direction indicated by current mouse direction
  • 1 , 2 . 5 Enter - Adds the next point at the absolute position 1 in X and 2.5 in Y
Specifying Further Properties
By using specific letter keys after your values, you can also specify the line segment in terms of angle and length. Using the key sequence value A value L cretes the next line segment at angle (A) degrees from the last point and with a length(L)
Examples
  • 45 A 3 L - Creates a line segment at 45 degrees and length 3
Next Point
You can also use the form to enter values for each line segment as you go along. The segments can be defined using:
  • The absolute X Y position of the next point
  • The Angle and Length to the next point
  • The relative offset in X (dx) and Y (dy) to the next point.
Once you have entered the values you wish to use:
  • Click the button to enter a new point.
  • The button deletes the last point entered and allows a new point to be added.
  • The button completes drawing the current line and leaves the form open to allow additional lines to be drawn.
